Programming Tutorial:Implementing an advanced Matlab-based Filter
This tutorial, written by Robert Oostenveld, shows you how to implement a filter based on a beamforming algorithm where the beamformer is updated in real-time, based on the covariance matrix of its input data.
What is Matlab?
“MATLAB® is a high-level language and interactive environment that enables you to perform computationally intensive tasks faster than with traditional programming languages such as C, C++, and Fortran.”
Advantages of Matlab
  • interactive
  • simple syntax
  • no explicit declaration of variables and functions required
  • garbage collection
  • standard for neuroscience data analysis
  • many toolboxes available
  • many algorithms implemented
  • many data visualisation tools
Disadvantages of Matlab
  • slower than compiled code
  • default double precision
  • not open source
  • expensive
  • language suitable for RAD, not so much for large projects
Real time processing for BCI
  • EEG alpha oscillation @10Hz
duration ~100 ms
decision every xx ms?
  • Processing as fast as possible
"real time"
In computer science, real-time computing is the study of hardware and software systems which are subject to a "real-time constraint”, i.e., operational deadlines from event to system response.
By contrast, a non-real-time system is one for which there is no deadline, even if fast response or high performance is desired or even preferred.
  • Deadline requirements vary, e.g.
continuous classification -> hard deadline
incremental evidence -> soft deadline
Motivation for combining BCI2000 and Matlab
  • rapid application development
  • try out various algorithms
  • offline analysis of data
  • port offline analysis to online
  • Matlab is fast enough for quite some computations
Matlab in the BCI2000 pipeline
  • BCI2000 filters are pipelined
  • each filter is a C++ object, there exists a Matlab filter that translates the C++ interface into Matlab
constructor -- define states and parameters, start Matlab engine
Preflight() -- check validity of parameters
Initialize() -- get parameter values
StartRun() -- setup computational space
StopRun() -- cleanup computational space
while data is streaming
Process() -- perform actual computation
destructor -- stop Matlab engine
  • correspondingly, there is a Matlab function corresponding to each C++ member function:
bci_Construct() -- define states and parameters, start Matlab engine
bci_Preflight() -- check validity of parameters
bci_Initialize() -- get parameter values
bci_StartRun() -- setup computational space
bci_Process() -- process a single data block
bci_StopRun() -- cleanup computational space
destructor() -- stop Matlab engine
Filter example: linear classification using a beamformer
Beamforming is a technique to extract source signals from a multi-channel recording. In this hands-on tutorial, we will use an adaptive spatial beamformer to compute a biophysically motivated source projection which is adapted to data covariance.
Adaptive Spatial Filtering
Region in the brain: r
Forward model: H(r)
Assumed neural activity: yr(t)
Model for the projection of the source to the channels (forward model H):
x(t)=H(r)yr(t)+n(t)
Estimate the strength of activity of the neural tissue at location r</math<<math>sr(t)=w(r)Tx(t)
sr(t)=w(r)TH(r)y(t)
An ideal spatial filter should pass activity from a location of interest with unit gain:
w(r0)H(r)=1,r=r0
while suppressing others
w(r0)H(r)=0,rr0
However, this is not always possible, and we compute an optimal spatial filter by minimizing the variance of the filter output (source activity):
minvar(sr)mintrace[w(r)Tcov(x)w(r)]
Two constraints:
w(r)H(r)=1
minvar(s)
After some algebra:
w(r)=[HT(r)cov1(x)H(r)]1HT(r)cov1(x)
The adaptive filter is computed from the forward model for a given position r, and the covariance matrix of the data.
Implementation with the BCI2000 Matlab filter
bci_StartRun function
function bci_StartRun
% shared BCI2000 Parameters and states are global variables.
global bci_Parameters bci_States
% the following variables are used in the computation, and are needed over multiple iterations
global fsample nchans nsamples
global sum_covariance sum_count
global norm_s norm_ss norm_n
global H C w
fsample  = sscanf(bci_Parameters.SamplingRate{1}, '%fHz');
nchans   = sscanf(bci_Parameters.SourceCh{1}, '%d');
nsamples = sscanf(bci_Parameters.SampleBlockSize{1}, '%d');
% these are for the accumulated normalization
norm_n  = 0;
norm_s  = 0;
norm_ss = 0;
% these are for the accumulated data covariance estimate
sum_covariance = zeros(nchans, nchans);
sum_count      = 0;
% this is the forward model, which describes how the source projects onto the channels
% in real applications the forward model would be computed using a biophysical model
% but here the source projects equally strong onto all channels
H = ones(nchans,1)/nchans;
% these are empty to start with
C = zeros(nchans, nchans);
w = zeros(1,nchans);
bci_Process Function
function out_signal = bci_Process( in_signal )
flt_signal = in_signal;
% apply baseline correction
for i=1:nchan
 flt_signal(i,:) = flt_signal(i,:) - mean(flt_signal(i,:));
end
% compute the covariance using a running sum
sum_covariance = sum_covariance + flt_signal*flt_signal';
sum_count      = sum_count      + 1;
% compute the beamformer spatial filter
C = sum_covariance/sum_count;
w = inv(H' * inv(C) * H) * H' * inv(C);
% apply the beamformer spatial filter to the data
out_signal = w * flt_signal;
% compute the total power in the signal for the present block
out_signal = sqrt(sum(out_signal.^2));
% we could in principle stop here, but normalization of the control signal is required as well
% the normalization could also be done with standard BCI2000 filter
% if the signal is all zero, then the inverse covariance cannot be computed
% which results in a filter output that is not a number (nan)
if ~isnan(out_signal)
 % compute the running sum of the beamformer power
 for i=1:numel(out_signal)
   norm_n  = norm_n  + 1;
   norm_s  = norm_s  + out_signal(i);
   norm_ss = norm_ss + out_signal(i)^2;
  end
end
% compute the normalized output
norm_avg   = norm_s / norm_n;
norm_std   = sqrt(norm_ss/norm_n - norm_s^2/norm_n^2);
out_signal = (out_signal - norm_avg)/norm_std;
Beamformer source reconstruction
  • adaptive spatial filter
  • implementation in few lines of Matlab code
  • recursive updating of covariance
  • output used as control signal
Conclusions
  • Small-batch processing in Matlab
  • Incremental algorithms
  • Within the pipeline
  • Useful for Rapid Application Development
  • Fast for Research & Development
  • Fast enough (?) for online applications
  • once proven, port algorithm to C++
Programming Tutorial:Implementing a Matlab-based Filter, Programming Reference:MatlabFilter, User Reference:MatlabFilter, Contributions:FieldTripBuffer
