Tracking categories
Appearance
This page lists tracking categories which are automatically populated by the MediaWiki software. Their names can be changed by altering the relevant system messages in the MediaWiki namespace.
| Tracking category | Message name | Category inclusion criteria |
| Pages with broken file links | broken-file-category | The page contains a broken file link (a link to embed a file when the file does not exist). |
| Pages using duplicate arguments in template calls | duplicate-args-category | The page contains template calls that use duplicates of arguments, such as {{foo|bar=1|bar=2}} or {{foo|bar|1=baz}}. |
| Pages where expansion depth is exceeded | expansion-depth-exceeded-category | The page exceeds the maximum expansion depth. |
| Pages with too many expensive parser function calls | expensive-parserfunction-category | The page uses too many expensive parser functions (like #ifexist). See Manual:$wgExpensiveParserFunctionLimit. |
| Hidden categories | hidden-category-category | The category contains __HIDDENCAT__ in its page content, which prevents it from showing up in the category links box on pages by default. |
| Indexed pages | index-category | The page has a __INDEX__ on it (and is in a namespace where that flag is allowed), and hence is indexed by robots where it normally wouldn't be. |
| Pages where node count is exceeded | node-count-exceeded-category | The page exceeds the maximum node count. |
| Noindexed pages | noindex-category | The page is not indexed by robots because it has the magic word __NOINDEX__ on it and is in a namespace where that flag is allowed. |
| Pages with non-numeric formatnum arguments | nonnumeric-formatnum | The page contains a non-numeric argument to the formatnum parser function. |
| Pages containing omitted template arguments | post-expand-template-argument-category | The page is bigger than $wgMaxArticleSize after expanding a template argument (something in triple braces, like {{{Foo}}}). |
| Pages where template include size is exceeded | post-expand-template-inclusion-category | The page size is bigger than $wgMaxArticleSize after expanding all the templates, so some templates were not expanded. |
| Pages with ignored display titles | restricted-displaytitle-ignored | The page has an ignored {{DISPLAYTITLE}} because it is not equivalent to the page's actual title. |
| Pages which use = as a template | template-equals-category | The page contains {{=}} but on this wiki that does not expand to =. This usage is deprecated; a future MediaWiki version will implement {{=}} as a parser function. |
| Pages with template loops | template-loop-category | The page contains a template loop, ie. a template which calls itself recursively. |
| Pages where the unstrip depth limit is exceeded | unstrip-depth-category | The page exceeds the unstrip depth limit. |
| Pages where the unstrip size limit is exceeded | unstrip-size-category | The page exceeds the unstrip size limit. |
| Pages with invalid language codes | bad-language-code-category | The page contains a {{#dir}} with an invalid language code. |
| Pages with invalid behavior switches | bad-double-underscore-category | The page contains a invalid localized behavior switch. Valid localizations begin and end with double underscores. |
| Pages with image sizes containing extra px | double-px-category | The page contains an image whose size contains an extra px suffix, like 100pxpx. |
| Pages with math errors | math-tracking-category-error | Pages in this category have errors in the usage of math tags. |
| Pages with math render errors | math-tracking-category-render-error | Pages in this category have rendering errors in the math tags. |
| Pages that use a deprecated format of the chem tags | math-tracking-category-mhchem-deprecation | Pages in this category use a deprecated format of the chem tags |
| Pages that use a deprecated format of the math tags | math-tracking-category-texvc-deprecation | Pages in this category use a deprecated format of the math tags |
| Pages with syntax highlighting errors | syntaxhighlight-error-category | There was an error when attempting to highlight code included on the page. |
| Pages using deprecated enclose attributes | syntaxhighlight-enclose-category | The syntaxhighlighting on the page uses deprecated enclose syntax. |
| Pages using deprecated source tags | syntaxhighlight-source-category | The syntaxhighlighting on the page uses deprecated source tags. |
| Pages with reference errors | cite-tracking-category-cite-error | Pages in this category have errors in the usage of references tags. |
| Pages that use extended references | cite-tracking-category-ref-extends | Pages in this category use the "extends" attribute of the <ref> tag. |
