Automatic Installation For Non-Windows
Prerequisites
  • Subversion
  • Qt (note: Qt version 5 works the best on non-windows platforms)
Downloading the Source Code
First, make sure that you have registered with BCI2000 (see Programming_Howto:Register_with_BCI2000_Project). Then run
svn checkout https://bci2000.org/svn/trunk <your install location>
Installing BCI2000
Open your BCI2000 directory in a finder or file viewer window. Next, double click the file named
install
It should open a new terminal window and prompt you for your qt installation location. Drag and drop your qt installation folder into the terminal window and press enter. Next, it will find the dependencies that it needs or install them automatically, if you do not have them. Finally, it will automatically build the project. When the script is finished running, your prog folder in your BCI2000 directory should have been filled with executable files.
