Compiling On Non-Windows Platforms
Configure BCI2000 for Compilation
Run the CMake GUI
Double-click "Configure.sh.cmd" in your BCI2000 build directory.
Tell CMake which Qt installation to use
Click "AddEntry" in the CMake window (Note that checking off "Advanced" in Cmake is optional and does not impact the compilation) and enter the path to a Qt directory. Use CMAKE_PREFIX_PATH as the name for the new entry. Be aware that the entry's name is case sensitive. Currently, on non-windows platform, Qt 5 is the only version that is supported.
Installing Dependencies
There are three dependencies that need to be installed before you can compile BCI2000:
  • ffmpeg (version 4.4.1, version 5 does not work with BCI2000)
  • portaudio
  • sdl2
These can be installed using the
install_dependencies
script in the BCI2000 home directory. Or, you can manually install them, and they will be automatically detected by CMake.
Perform the configuration step
In the CMake window, click "Configure" and choose a generator that is consistent with your compiler. This tutorial will be using Unix Makefiles. Then click "Done" to perform the configuration step. You will see a list of targets scrolling by, and a number of new entries in the variable list at the top of the window, marked in red.
Choose Build Options
Make sure the "Grouped" checkbox is checked, and configure the build by customizing values in the "BUILD" group, "EXTENSIONS" group, and "USE" group. Then, click "Generate" to create build files. When CMake displays its "Generating done" message, your BCI2000 build directory will now contain a Makefile (or a project file for your compiler of chioce), as well as a number of additional CMake-generated files.
Compile BCI2000
Open Terminal
Open a new terminal window and navigate to your BCI2000 build directory.
Build Makefiles
Run:
make
from your BCI2000 build directory. Once this is finished your BCI2000 prog directory will contain a number of executables, one for each module, plus a few helper executables. Not everything works the same or, in some cases, at all on non-windows platforms. See, Non-Windows Functionality for more information.
