Contributions:CP2130Filter
The CP2130Filter allows for the interaction with Silicon Labs CP2130 board. This board uses a USB-SPI bridge that allows for commands to be sent to the board and data to be acquired from sensors.
To use this filter, a CP2130 board must be connected to the computer via USB.
http://www.bci2000.org/svn/trunk/src/private/SignalProcessing/CP2130
Yichuan Wang, Alex Belsten
- Initial development: 5799
- Tested under: 5799
- Known to compile under: 5800
StimulationExpression
Evaluated expression for the stimulation of StimulatingGPIO. The default value State(MouseKeys)==1 evaluates true when the left mouse key is clicked. Therefore, when the left mouse is clicked, StimulatingGPIO is stimulated. See User Reference:Expression Syntax for more details.
StimulatingGPIO
GPIO pin on the board that is stimulated. Default value is 0. Acceptable values range from 0-8.
Temperature
32 bit raw value from on-board temperature sensor
Potentiometer
32 bit raw value from on-board potentiometer
InputADC
32 bit raw value from on-board ADC input. Usefully for connecting to function generator.
