Contributions:EglyDriverTask
Timeline
Visual Representation
Huiling Huang (huiling@neurotechcenter.org) implemented the paradigm into BCI2000.
titration rule
In titration task, we use 3-down-1-up to adjust the contrast: decrease the contrast by one degree if 3 consecutive correct responses happens. Increase the contrast by one degree if 1 incorrect response happens.
In the main task:
1. Start with the first 15 trials:
Record accuracy for the initial 15 match trials.
Calculate the average accuracy of these trials.
Adjust the contrast based on the computed average.
2. Ongoing updates with a sliding window:
After every set of 5 new trials:
Incorporate these 5 new trials into the dataset.
Remove the oldest 5 trials from the sequence.
Recalculate the average accuracy of the updated 15-trial window.
Adjust the contrast accordingly.
This process continues for every subsequent batch of 5 trials.
PushButtonType
We provide 3 sources of pushbuttons: DC, analog, and keyboard.
DC and analog: the push button is directly connected to the amplifier; the delay is minor and can be ignored. Please confirm the variable name where the PushButtom is stored with the experimenter. The variable name varies with the channel that the push button connects to through the amplifier.
keyboard: usually has tens of milliseconds delay.
FixationColor, BarColor, CueColor, TargetColor
The color of the fixation, bar, cue, target.
BarThick
The thickness of the bar. range [0,1]
FixationWidth
The width of the fixation cross. range [0,1]
CueThick
The thickness of the cue. range [0,1]
TargetWidth
The width of the target. range [0,1]
FixationDurationMin, FixationDurationMax
Minimum/Maximum duration of the fixation phase.
BarDurationMin, BarDurationMax
Minimum/Maximum duration of the bar phase.
CueDuration
Duration of cue.
CueToTargetDurationMin, CueToTargetDurationMax
Minimum/Maximum interval time between cue and target.
TargetDuration
Duration of target.
PostTargetResponseTime
The maximum time allows the subject to respond after the target disappears.
FeedbackDuration
Duration of the feedback
TotalTrial
Number of the total trials.
CatchTrialPerctg
The percentage of the catch trial(no target)(%). range [0,100]
CueTgtMatchPerctg
The percentage of the cue matches the target trial(%). range [0,100]
CueTgtSmObjctPerctg
The percentage of the target mismatches the cue, on the same object(%). range [0,100]
CueTgtDifObjctPerctg
The percentage of the target mismatches the cue, on the different objects(%). Set as 0 when it is a simplified task. range [0,100]
ScreenWidth, ScreenHeight
Width/height of the monitor screen in cm.
EyeToSreenDistance
Distance from the subject's eyes to the screen in cm.
VisualAngle
The degrees of visual angle. range [0,360]
AdjustContrastBy
Adjust the contrast of the target color by: 0 overall accuracy, 1 match accuracy, 2 non-match accuracy.
AdjustContrastTrialNum
The number of trials needed to calculate the accuracy for adjusting the contrast.
AdjustContrastUpdateTrialNum
The number of update trials needed to calculate the accuracy for adjusting the contrast.
AccuracyUp
The up boundary of the accuracy. range [0,1]
AccuracyLow
The low boundary of the accuracy. range [0,1]
Simplified
Enable the simplified version, only has two squares rather than two bars.
SquareLength
The lenght of square in simplified version. range [0,1]
IsStairCase
Enable the Staircase.
DownCounts
Contrast decreases one step following the number of consecutive correct trials.
UpCounts
Contrast increases one step following the number of consecutive incorrect trials.
ProgressBar
Display progress bar.
ProgressBarHeight, ProgressBarWidth
Progress bar height/width in pixels.
ProgressBarBackgroundColor, ProgressBarForegroundColor
Color of progress bar background/foreground.
PhotoDiodePatch
Display a photo diode patch on the stimulus window. Recording from a photo diode located on that patch will allow triggering on actual stimulus delivery (see User_Reference:P3TemporalFilter#OnsetExpression).
PhotoDiodePatchHeight, PhotoDiodePatchWidth
Photo diode patch height/width in relative coordinates (between 0 and 1).
PhotoDiodePatchLeft, PhotoDiodePatchTop
Photo diode patch left/top position in relative coordinates (between 0 and 1).
PhotoDiodePatchShape
Photo diode patch shape: 0 rectangle, 1 ellipse.
PhotoDiodePatchActiveColor
Photo diode patch color when active (RGB color in format 0xrrggbb).
PhotoDiodePatchInactiveColor
Photo diode patch color when inactive, (RGB color in format 0xrrggbb, use 0xff000000 for transparent).
KeyDown, KeyUp, DCXX, PushButton
Recording when the subject is pushing or releasing the button.
We provide 3 sources of pushbuttons: DC, analog, and keyboard. DC and analog: The push button is directly connected to the amplifier, so the delay is minor and can be ignored. Please confirm the variable name where the PushButtom is stored with the experimenter. The variable name varies with the channel the push button connects to through the amplifier. Usually, the variable name begins with "DC"; for example, "DC02", the number "02" is the channel ID.
Keyboard: This usually has a tens of millisecond delay. When a key is pressed, "KeyDown" will be set to the key's virtual key code at the corresponding sample position. When a key is released, the key code will be written into the "KeyUp" state variable.
We also have a backup State called "PushButton." It registers when the software detects the keyboard or button push or release. There is a delay after the software detects the response, so the backup "PushButton" happens later than the actual keyboard or button response. You only need the backup "PushButton" when the "DCXX" or "KeyDown" is not available for some reason.
PhaseNumber
The index of phase in each trial. (8 bits) 0: none; 1: Beginning of the trial; 2: Fixation; 3: Bar; 4: Cue; 5: Cue to target; 6: Target; 7: Post target response; 8: Feedback.
TrialNumber
Index of trials. (16 bits)
BarDirection
Main task: 1: Vertical; 2: Horizontal.
Simplified task: 1: LeftTop; 2: RightTop; 3: RightBottom; 4: LeftBottom.
CuePosition, TargetPosition
TrialType
1: no target, catch trial;
2: cue target match;
3:cue target don't match, on the same object;
4: cue target don't match, on the different object;
FixationDuration
Duration of the phase Fixation by the number of blocks.
BarDuration
Duration of the phase Bar by the number of blocks.
CueToTargetDuration
Duration of the phase CueToTargetDuration by the number of blocks.
TargetColor
The color of the target. Represent in decimal numbers.
Response
1: correct.
2: incorrect
Photodiode
The Photodiode is stored in the .bat file, and the name begins with "DC". For example, "DC03", the number after "DC" represents the channel number, because the photodiode is directly connected to the amplifier, the name depends on the hardware connection. Please confirm the name of the Photodiode with the experimenter before starting the analysis.
We also have a backup State called "Photodiode". It registers when the software sends the command to hardware to present the stimulus or whenever we need to flash the photodiode. Between the software sending the command to the hardware actual response, there are roughly about 20 ms delays. So the backup "Photodiode" happens earlier than the actual photodiode flashes. You only need the backup Phtodiode when the "DCXX" is not available for some reason.
1: active;
2: non-active
Contributions:Applications
