Contributions:NeuroscanADC
The NeuroscanADC component implements the client side of the TCP/IP-based Neuroscan Acquire protocol. Thus, it may be used to interface BCI2000 with Neuroscan EEG systems.
http://www.bci2000.org/svn/trunk/src/contrib/SignalSource/Neuroscan
In recent versions of BCI2000, the executable for this source module is called NeuroscanClient. Earlier, it was called Neuroscan.
Gerwin Schalk, (c) 2004 Wadsworth Center, New York State Department of Health.
- V1.00 - 04/28/2004 - First working version
- V1.10 - 05/17/2004 - Now includes support for 32bit data
- Initial development: 268
- Tested under: 1110
- Known to compile under: 1528
NuAmps/SynAmps are EEG recording systems from Neuroscan, Inc., that are widely used in clinical settings. The increasing use of BCI2000 in those environments created the need for Neuroscan support in BCI2000. This page describes this support that consists of two components: A BCI2000-compatible Source Module (NeuroscanClient.exe) and a command-line tool (neurogetparams). These components are described below and have been tested with Neuroscan Acquire version 4.3.1.
Neuroscan Source Module
The BCI2000-compatible Source Module NeuroscanClient.exe can be used instead of any other source module. In addition to standard parameters (i.e. SampleBlockSize, SamplingRate, SourceCh), it only requests one Neuroscan-specific parameter (ServerAddress) that defines the IP address (or host name) and the port number of the Acquire server. An example for an appropriate definition is localhost:3999. Before starting BCI2000, you need to start Acquire, click on the S symbol in the top right corner (to enable the server) and start the server on any port. Please note that by default, Acquire suggests port 4000, which is a port used by BCI2000. You might use port 3999 instead. Once the server is running, you can start BCI2000. It is imperative that certain parameters (e.g., the number of channels) in BCI2000 match the settings in Acquire. You can read these settings from Acquire using the command line tool described in the following section. This command line tool can create a parameter file fragment that needs to be loaded on top of an existing parameter file every time a setting in Acquire is changed.
Undocumented Communication
Neuroscan Acquire supports communication options that are not documented in the NetAcquire.doc document. BCI2000 needs to use two of them, the request for basic Neuroscan configuration information (which will return information such as the number of channels and the sampling rate) and the receipt of packets of data, to function properly. They are listed below:
| Packet ID | Code | Request | Body Size |
| "CTRL" | 3 (Client Ctrl Code) | 5 (Req Basic Info) | 0 |
| "DATA" | 1 (Datatype Info) | 3 (InfoType BasicInfo) | bodyLen |
| "DATA" | 2 (EEG Data) | 1 (Raw 16-bit) | bodyLen |
Request Basic Information
The client sends a request for basic information ("CTRL", Client Ctrl Code, Req Basic Info). The server responds by sending a data block ("DATA", Datatype Info, InfoType BasicInfo) that contains a data structure describing the current configuration of data acquisition in Acquire. This data structure is as follows:
struct AcqBasicInfo
DWORD dwSize; // Size of structure, used for version control
int nEegChan; // Number of EEG channels
int nEvtChan; // Number of event channels
int nBlockPnts; // Samples in block
int nRate; // Sampling rate (in Hz)
int nDataSize; // 2 for "short", 4 for "int" type of data
float fResolution; // Resolution for LSB
The first element, dwSize, can and should be cross checked with the length of the structure AcqBasicInfo and must match.
Receive 16-bit Data Packet
The client may send a Request to Start Sending Data to the Acquire server (as described in the NetAcquire.doc document). This will prompt the server to start sending blocks of raw signal values. In order to interpret these signal values, the client must first have sent a Request for Basic Information, as described above. The incoming data packets ("DATA", EEG Data, Raw 16-bit) can then be interpreted using this information and the code below.
// make sure the body has the right length
assert((int)(pMsg->m_dwSize) ==
(int)(m_BasicInfo.nEegChan+m_BasicInfo.nEvtChan)
*m_BasicInfo.nBlockPnts*m_BasicInfo.nDataSize);
// process raw 16 bit data
for (int samp=0; samp<m_BasicInfo.nBlockPnts; samp++)
for (int ch=0; ch<m_BasicInfo.nEegChan+m_BasicInfo.nEvtChan; ch++)
short *sample=(short *)pMsg->m_pBody;
printf("%d ", sample[samp*(m_BasicInfo.nEegChan+m_BasicInfo.nEvtChan)+ch]);
ServerAddress
Address and port of the Neuroscan Acquire server, given in address:port format.
NeuroscanEvent1
An 8-bit state that encodes event information as sent over the Neuroscan Acquire protocol.
The neurogetparams Command Line Tool
This command line tool reads system settings from the Neuroscan Acquire server, displays them on a screen and creates a BCI2000 parameter file fragment if desired. It can be used as follows: neurogetparams -address localhost:3999 -paramfile test.prm. (The Acquire server has to be enabled before using this tool.) Once BCI2000 is configured correctly, this parameter file fragment needs to be loaded on top of the existing configuration to make sure that the settings match. You only need to repeat this procedure if you change settings in Acquire (e.g., such as the number of channels or the amplification).
BCI2000 Parameter Tool for Neuroscan Acquire V4.3
(C)2004 Gerwin Schalk and Juergen Mellinger
Wadsworth Center, New York State Dept of Health, Albany, NY
Eberhardt-Karls University of Tuebingen, Germany
Signal Channels: 32
Event Channels: 1
Block Size: 40
Sampling Rate: 1000
Bits/Sample: 16
Resolution: 0.168uV/LSB
Parameter file test.prm successfully written
