Contributions:SecondaryBCI2000Controller
An extension that controls one or more secondary BCI2000 instances from the GUI of a primary one.
http://www.bci2000.org/svn/trunk/src/contrib/Extensions/SecondaryBCI2000Controller
  • Jürgen Mellinger (mellinger@neurotechcenter.org)
  • Initial development: 6819
  • Tested under: 9500
  • Known to compile under: 9500
Known Issues
  • Log windows of primary and secondary BCI2000 instances will initially have the same location, hiding each other and possibly leading to confusion. The same applies to operator main windows if secondary instances are not hidden by calling "Hide Window" from the secondary batch file(s).
The extension will start up one or more secondary instances of BCI2000, and synchronize data file storage and operation state between the instances. This is useful to record from two or more different data sources at the same time, when online processing of secondary data sources is not required. In later analysis, data from the multiple sources may be aligned in time using BCI2000 time stamps found in the data files.
Compile the extension into your source module by enabling contributed extensions in your CMake configuration. In your root build folder, run Configure.sh.cmd in order to bring up the CMake GUI; there, enable EXTENSIONS_SECONDARY_BCI2000_CONTROLLER.
Once the extension is built into the source module, enable it by starting the source module with the --SecondaryBCI2000=1 command line argument.
Usage
When the SecondaryBCI2000Controller extension has been enabled in the system at compile time, you will find a BCI2000TwiceStartup.bat batch file in your BCI2000 batch folder. Double-click it to start BCI2000.
Startup configuration of secondary BCI2000 instances is done in the files BCI2000SecondaryStartup.bat, BCI2000Secondary2Startup.bat, etc. You may load identical or different configuration parameter files in the startup batch files.
Data file location is synchronized between BCI2000 instances. Secondary instances use identical file names to the first one, with an appended _1, _2, ... before the file name extension.
The SecondaryBCI2000Controller extension is configured in the Source tab within the "Secondary BCI2000" section. The configurable parameters are:
SecondaryBCI2000
Enables/Disables the SecondaryBCI2000Controller.
SecondaryBCI2000Instances
A matrix with one row per secondary instance.
The first column contains the telnet port that is used to control the secondary instance of BCI2000.
The second column contains the the script that is used to start up and configure the secondary instance of BCI2000. An example script is available as BCI2000SecondaryStartup.bat in your BCI2000 batch directory, and is called by the BCI2000TwiceStartup.bat batch file.
To tell the second instance that it should refer to the first one for file names, there is a command line parameter:
IsSecondaryBCI2000
This parameter must be set in the secondary instance's batch file: --IsSecondaryBCI2000=1.
In case of multiple secondary instances, it must be set to a unique instance ID greater 0. This ID appears in the file name of the secondary instance, e.g. Data01R01_3.dat if --IsSecondaryBCI2000=3.
Contributions:Extensions, User Reference:Operator Module Scripting
