Programming Howto: Install Prerequisites on Non-Windows Platforms
Back
to the overview page
Homebrew
Homebrew is a package manager for macOS and Linux that we will be using to install several items. You may also use another package manager if you have one that you prefer. Install it using the terminal window with
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
Follow the instructions in the terminal to finish the installation.
Now check to make sure that it was installed correctly with
brew --version
SVN
SVN is used to checkout the source code repository. Install it with
brew install Subversion
svn --version
Qt6
Qt is used to render to BCI2000 windows. Qt version 6 is the only version that is supported on Non-Windows Platforms.
Unfortunately, the homebrew version of Qt6 is broken and cannot be used with BCI2000.
Rather than using homebrew, go to the Qt website and download the Qt installer for Open Source use from there: https://www.qt.io/download-qt-installer-oss
In the installer, choose a version of Qt6 to install.
NOTE: For building on macOS Tahoe or newer, Qt6 6.8.4 or newer is required. With older versions of Qt6, building will fail with linker errors.
CMake
CMake is used to customize BCI2000 builds. Install it with
brew install cmake
Now check to make sure that it was install correctly with
cmake --version
Next
Register with BCI2000
