Programming Reference:ComplexVisualizationDemo Signal Processing
src/contrib/SignalProcessing/ComplexVisualizationDemo
The ComplexVisualizationDemo signal processing module demonstrates how to send a large number of visualizations with arbitrary pixel content to the operator module. Two rendering methods are provided: Native Qt QPainter-based rendering, and BCI2000's own GraphDisplay based rendering.
Inheritance
The ComplexVisualizationDemoFilter signal processing filter derives from GenericFilter.
The ComplexVisualizationDemoFilter computes pairwise determination coefficients (squared correlation, r2 values) between its input channels. Determination coefficients are visualized in form of pie charts, and pie charts are sent to the operator module as bitmap visualization data.
Operator visualization windows have no frames or title bars, and are arranged in form of a triangular matrix, with each window appearing at the place of its associated correlation matrix element:
Implementation
Each visualization window is implemented as a VisualizationObject that contains a BitmapVisualization object, a WorkerThread object, and a Computation object. Whenever a new block of data arrives, computation is done for the individual window's pair of channels in the main thread. Then, visualization bitmap data are produced and sent to the operator module inside the worker thread, to avoid blocking the main thread. Inside the worker thread, the BitmapVisualization's SendDifferenceFrame() function is called to update the visualization display in the operator module.
Declaration of internal variables
The code example uses a pointer to an internal private struct to hide implementation details from the outer header file of the filter class (PIMPL idiom).
A VisualizationObject class is declared that contains all members necessary to draw to an individual visualization window, and a WorkerThread instance that runs code to send visualization data to the operator in a separate thread in order to avoid interference with the timing of the main BCI2000 thread.
struct ComplexVisualizationDemoFilter::Private
  RGBColor mBackground;
  int mHeight, mWidth, mDecimation;
  int mDecimationCounter;
  class VisualizationObject;
  std::vector<VisualizationObject*> mVisualizations;
  ~Private() { destroyVisualizations(); }
  // Creates visualization objects for pairs of channels.
  void createVisualizations(const SignalProperties&, int maxWindows);
  // Destroys all visualization objects.
  void destroyVisualizations();
  // Resets visualizations to their initial state.
  void resetVisualizations();
  // Computes data values, and asynchronously updates visualization bitmaps.
  void updateVisualizations(const GenericSignal&);
  // Waits for asynchronous activity in all visualizations to terminate.
  void waitForVisualizations();
  public:
    VisualizationObject(const Private*, const std::string& visID);
    ~VisualizationObject();
    void setTitle(const std::string&, const std::string& info = "");
    void setPosition(int row, int col, int rowSpan = 1, int colSpan = 1);
    void reset();
    void update(const GenericSignal&);
    void wait();
    struct Computation
      int inputCh1, inputCh2;
      double result;
      // run() is called whenever a new signal arrives.
      void run(const GenericSignal&);
    } mComputation;
  private:
    void asyncUpdate();
    MemberCall<void(VisualizationObject*)> mCallAsyncUpdate;
    const Private* p;
    WorkerThread mWorker;
    BitmapVisualization mVis;
    std::string mTitle, mInfo;
    GUI::Rect mPosition;
    GUI::GraphDisplay mImage;
    PieShape* mpShape;
    TextField* mpValueField, *mpInfoField;
VisualizationObject::update()
This function runs VisualizationObject::asyncUpdate() inside the object's worker thread in order to avoid interference with timing of the main BCI2000 thread (pipeline thread).
void
ComplexVisualizationDemoFilter::Private::VisualizationObject::update(const GenericSignal& Input)
  mComputation.run(Input);
  mWorker.Run(mCallAsyncUpdate); // will fail silently if worker still busy
VisualizationObject::reset()
This function resets the visualization window's position and size before sending an empty reference frame to the operator.
void
ComplexVisualizationDemoFilter::Private::VisualizationObject::reset()
  // place window into a container window named "CPLX" (will be created implicitly)
  mVis.Send(CfgID::PlacementVis, "CPLX");
  mVis.Send(CfgID::PlacementRow, mRow);
  mVis.Send(CfgID::PlacementCol, mCol);
  mVis.Send(CfgID::WindowFrame, false); // hide title
  mVis.Send(CfgID::Visible, true);
  // paint an empty image
  mpInfoField->SetText(mInfo);
  mpInfoField->SetVisible(true);
  mpValueField->SetVisible(false);
  mpShape->SetVisible(false);
  mImage.SetColor(p->mBackground);
  mImage.Paint();
  mVis.SendReferenceFrame(mImage.BitmapData());
  mpShape->SetVisible(true);
  mpValueField->SetVisible(true);
  mpInfoField->SetVisible(false);
The asyncUpdate() function gets the computation result from the computation object, and draws a pie shape with an angle that corresponds to the result. It then sends the resulting image to the operator module as a difference frame.
void
ComplexVisualizationDemoFilter::Private::VisualizationObject::asyncUpdate()
  double value = mComputation.result;
  std::ostringstream oss;
  oss << std::setprecision(2) << std::fixed << value;
  mpValueField->SetText(oss.str());
  // Draw a pie shape that is full angle when value == 1, and that reduces to a line when value == 0.
  float angle = 270;
  if(value == value) // not NaN
    angle = 360 * value;
  mpShape->SetStartAngle(180 - angle/2).SetEndAngle(180 + angle/2);
  // render the image
  mImage.Paint();
  // send bitmap data to operator
  mVis.SendDifferenceFrame(mImage.BitmapData());
Process() function
The Process() function handles the test of the decimation counter, and calls updateVisualizations() if necessary. updateVisualizations(), in turn, calls VisualizationObject::update() for each visualization object contained in mVisualizations.
void ComplexVisualizationDemoFilter::Process(
  const GenericSignal& Input,
        GenericSignal& Output)
  Output = Input;
  if(p->mDecimationCounter == 0)
    p->updateVisualizations(Input);
  ++p->mDecimationCounter %= p->mDecimation;
StartRun() and StopRun()
These reset the decimation counter, and indirectly call VisualizationObject::reset(). The waitForVisualizations() function in StartRun() waits for all WorkerThread tasks to complete before actually re-starting visualization activity.
void ComplexVisualizationDemoFilter::StartRun()
  p->mDecimationCounter = 0;
  p->waitForVisualizations();
  p->resetVisualizations();
void ComplexVisualizationDemoFilter::StopRun()
BCI2000 GraphDisplay vs. QPainter rendering
The code presented here is using the BCI2000 GraphDisplay class.
GraphDisplay is a layer of abstraction that allows to render shapes and text objects into a normalized coordinate system. Code that uses GraphDisplay is most likely to survive breaking changes in the drawing backend (currently Qt) and BCI2000 dependencies.
In contrast, QPainter-based rendering provides access to more complex drawing functions but suffers from a limitation in Qt which makes text rendering impossible outside the main GUI thread.
In the ComplexVisualizationDemo source code, QPainter-based rendering is available through a compiler switch.
VisImageWidth
Native image width in pixels.
VisImageHeight
Native image height in pixels.
VisImageBackground
The images' background color, in hexadecimal notation.
VisImageDecimation
A positive integer that indicates how often images are refreshed. 1 means refresh on every signal packet.
VisMaxWindows
The maximum number of visualization windows created, or 0 for any number of windows.
Programming Reference:GraphDisplay Class, Programming Reference:GenericVisualization Class, Programming Reference:VisualizationDemo Signal Processing, Programming Reference:VisualizationContainerDemo Signal Processing, Technical Reference:Visualization Properties
