Programming Reference:RectangularShape Class
src/shared/gui/Shapes
The RectangularShape class represents a rectangle drawn onto a GraphDisplay. Typically, it is used to represent a 2D feedback cursor or target.
Show()
Hide()
Makes the object invisible.
Invalidate()
Paint()
Change()
bool Click(GUI::Point)
GUI::Point Center
The shape's center of mass, i.e. what would be considered its "position". For simple shapes, this coincides with the center of the shape's bounding rectangle.
float LineWidth
The shape border's line width, in pixels.
RGBColor FillColor
The shape's filling color.
RGBColor Color
The color of the shape's border.
GraphDisplay Display (r)
bool Visible (r)
float ZOrder (rw)
enum ScalingMode (rw)
One of the following options:
- AdjustNone
- No adjustment is made.
- AdjustWidth
- The object's width is adapted to its contents, while keeping its height constant.
- AdjustHeight
- The object's height is adapted to its contents, keeping its width constant.
- AdjustBoth
- Both the object's height and width are adjusted to its content.
GUI::Rect ObjectRect (rw)
GUI::Rect DisplayRect (r)
Programming Reference:Shape Class, Programming Reference:GraphObject Class, Programming Reference:GraphDisplay Class
