Programming Reference:SignalSharingDemoClient C++ App
src/core/SignalProcessing/SignalSharingDemo
The SignalSharingDemo client demonstrates how to receive signal data from BCI2000, using shared memory. SignalSharing allows to tap into BCI2000 processing by receiving any filter output signal through a combination of a TCP connection, and shared memory.
For clarity, this page describes a simplified version of the SignalSharingDemo client, receiving only signal data, and not using the back channel to send back signal and state data. The full version in SVN shows how to use the full possibilities available to a SignalSharing client.
The SignalSharing component in BCI2000 shares its input signal through a GenericSignal object which has been linked to a shared memory block using GenericSignal::ShareAcrossModules(). A dedicated thread waits for signal updates, and sends signal data out to a separate application waiting on a TCP/IP connection.
When the client application is running on a separate machine, full signal data are sent over the network. When the client is running on the same machine, only a reference to a shared memory block is sent. On the application side, unserializing the signal will transparently bind it to the shared memory block if available.
The client application visualizes signal data by plotting normalized signals on a circle.
Client application code
The client application uses parts of the BCI2000 framework to efficiently receive and decode BCI2000 messages. To include it into your own project, use
utils_include(Frameworks/Core)
in your CMake file if it is part of the BCI2000 project.
Otherwise, you might to have to create code for dealing with BCI2000 messages yourself (message format definitions may be found here and here).
Declaration of internal variables
#include "SignalSharingDemoWidget.h"
#include "Sockets.h"
#include "StringUtils.h"
#include "Streambuf.h"
#include "Thread.h"
#include "GenericSignal.h"
#include "ParamList.h"
#include "Synchronized.h"
#include "Runnable.h"
#include <QPaintEvent>
#include <QPainter>
struct SignalSharingDemoWidget::Private
  SignalSharingDemoWidget* mpSelf;
  std::vector<QColor> mSignalColors;
  ServerTCPSocket mListeningSocket;
  Synchronized<bool> mConnected;
  SynchronizedObject<GenericSignal> mpSignal;
  SynchronizedObject<ParamList> mpParameters;
  Thread mThread;
  void ThreadFunc();
  MemberCall<void(Private*)> mThreadCall;
  void Invalidate();
  Private();
Initialization of internal variables
SignalSharingDemoWidget::Private::Private()
: mThreadCall(&Private::ThreadFunc, this),
  mThread(&mThreadCall, "SignalSharingDemoWidget listening/receiving thread")
  mSignalColors.resize(8);
  for(int i = 0; i < mSignalColors.size(); ++i)
    mSignalColors[i].setHsvF(i*1.0/mSignalColors.size(), 1, 0.9);
Receiving thread function
By inheriting from the MessageChannel class, the Private object will receive dispatched messages through overridden functions:
struct SignalSharingDemoWidget::Private : MessageChannel
    // MessageChannel overrides
    bool OnVisSignalProperties(std::istream&) override;
    bool OnVisSignal(std::istream&) override;
    bool OnParam(std::istream&) override;
void SignalSharingDemoWidget::Private::ThreadFunc()
    while (!mThread.Terminating())
    { // wait for a connection
        while (mListeningSocket.Input().Wait())
        { // accept pending connection
            ClientTCPSocket clientSocket;
            if (mListeningSocket.WaitForAccept(clientSocket, 0))
                mConnected = true;
                Invalidate();
                mBuffer.SetInput(&clientSocket.Input());
                MessageBuffer::ClearIOState();
                while (clientSocket.Input().Wait()) // will be interrupted by Thread::Terminate()
                    MessageChannel::HandleMessage(); // will dispatch to our overridden functions
                                                     // as appropriate
                *mpSignal.Mutable() = GenericSignal();
                mConnected = false;
                Invalidate();
bool SignalSharingDemoWidget::Private::OnVisSignalProperties(std::istream& is)
    VisSignalProperties properties; // signal properties are wrapped into VisSignalProperties
    properties.Unserialize(is);
    // The only information we need from signal properties is the sampling rate
    // because the signal's dimensions will be transported by signal messages as well.
    double sampleDuration = properties.SignalProperties().ElementUnit().RawToPhysicalValue(1);
    mSamplingRate = 1.0 / sampleDuration;
    return true; // indicate we read our data from the stream
bool SignalSharingDemoWidget::Private::OnVisSignal(std::istream& is)
    VisSignal visSignal; // signals are wrapped into VisSignal messages
    visSignal.Unserialize(is);
    mpSignal.Mutable()->AssignValues(visSignal.Signal()); // get current signal content
    Invalidate(); // request window update
bool SignalSharingDemoWidget::Private::OnParam(std::istream& is)
    Param param;
    param.Unserialize(is);
    mpParamList.Mutable()->Add(param);
The widget's paintEvent()
void
SignalSharingDemoWidget::paintEvent(QPaintEvent* ev)
  ev->accept();
  WithLocked(pSignal = p->mpSignal.Const()) // lock the signal while reading from it
    if(pSignal->Empty())
      QPainter painter(this);
      painter.fillRect(ev->rect(), Qt::gray);
      painter.setPen(Qt::white);
      painter.drawText(geometry(), Qt::AlignCenter,
        p->mConnected ? "Waiting for signal ..." : "Waiting for connection ...");
    else
       // draw some visualization into the widget
ShareTransmissionFilter
IP address and port number of the client application. The client's default address is localhost:1879 but may be changed on the client's command line.
The example uses the ShareTransmissionFilter parameter but any other filter's Share<FilterName> parameter under the SignalSharing tab will work as well to visualize the chosen filter's output signal.
User Reference:SignalSharing, Programming Reference:GenericSignal Class, Programming Reference:SignalSharing Python Demo, Programming Reference:SignalSharingClientLibDemo
