Programming Reference:TextStimulus Class
The TextStimulus class provides a VisualStimulus that displays text.
string Text (rw)
The text displayed in the stimulus area.
RGBColor IntensifiedColor
Determines text color during presentation when PresentationMode is set to Intensify.
Inherited from VisualStimulus
enum PresentationMode (rw)
This property determines the way a stimulus is presented. It is one of the following:
- ShowHide
- The stimulus is initially invisible, and visible while being presented.
- Intensify
- During presentation, the contrast of the stimulus is increased.
- Grayscale
- During presentation, the stimulus is displayed in grayscale rather than color.
- Invert
- During presentation, the stimulus appears color-inverted.
- Dim
- During presentation, the contrast of the stimulus is reduced.
- HideShow
- The stimulus is initially visible, and invisible while being presented.
float DimFactor (rw)
Determines the contrast ratio between presentation and non-presentation in Dim and Intensify modes. In Intensify mode, values greater 1 will result in a brighter appearance during presentation; in Dim mode, values greater 1 will result in a darker appearance during presentation. Due to saturation effects, the result may not be as expected.
Inherited from TextField
string Text
The text to be displayed.
float TextHeight
The text height in units of text field height. Typically, this would be between 0.6 and 0.8.
RGBColor TextColor
The color used to draw text.
RGBColor Color
The text field's background color.
GraphDisplay Display (r)
bool Visible (r)
float ZOrder (rw)
enum ScalingMode (rw)
One of the following options:
- AdjustNone
- No adjustment is made.
- AdjustWidth
- The object's width is adapted to its contents, while keeping its height constant.
- AdjustHeight
- The object's height is adapted to its contents, keeping its width constant.
- AdjustBoth
- Both the object's height and width are adjusted to its content.
GUI::Rect ObjectRect (rw)
GUI::Rect DisplayRect (r)
Show()
Hide()
Makes the object invisible.
Invalidate()
Paint()
Change()
bool Click(GUI::Point)
Programming Reference:VisualStimulus Class, Programming Reference:TextField Class
