Template:GraphObjectProperties
GraphDisplay Display (r)
bool Visible (r)
float ZOrder (rw)
enum ScalingMode (rw)
One of the following options:
- AdjustNone
- No adjustment is made.
- AdjustWidth
- The object's width is adapted to its contents, while keeping its height constant.
- AdjustHeight
- The object's height is adapted to its contents, keeping its width constant.
- AdjustBoth
- Both the object's height and width are adjusted to its content.
GUI::Rect ObjectRect (rw)
GUI::Rect DisplayRect (r)
