Template:StimulusTaskParams
WindowBackgroundColor
PreRunDuration
PostRunDuration
PreSequenceDuration
StimulusDuration
EarlyOffsetExpression
Allows the specification of an Expression that is constantly monitored during stimulus presentation. When the value of the Expression transitions from zero to non-zero, the stimulus is aborted early, even if the StimulusDuration has not yet elapsed. For example, set this Expression to KeyDown==32 and start your source module with the --LogKeyboard=1 flag: then the subject will be able to advance the stimulus sequence manually by pressing the space key.
InterpretMode
  • 0: no target is announced "attended", and no classification is performed;
  • 1: online or free mode: classification is performed, but no "attended target" is defined;
  • 2: copy mode: "attended" targets are defined, classification is performed.
DisplayResults
MinimumEvidence
NOTE: If you are using your own classifier, this feature will not work properly unless your classifier's output matches certain criteria. Make sure to read these notes on how to use a different classifier.
By default, target selection is performed without considering the actual amount of evidence that favors the selected target over other targets. Although the selected target will always be a target with maximum classification score (i.e., evidence), other targets may have the same or a similar score. It may be useful to omit classification in such situations altogether, by specifying a minimum amount of evidence that must exist in favor of the selected target, when compared to the next-best target. When used together with the AccumulateEvidence option, this allows to dynamically control the number of stimulus presentations, by simply repeating stimulus sequences until a sufficient amount of evidence has been collected.
Setting MinimumEvidence to 0 or to a negative number will result in default behavior, i.e. there will be a target selection each time classification scores are received from the SignalProcessing module. For values greater 0, the amount of selection errors will become smaller as the value of MinimumEvidence is increased; this increases the amount of information contained in each selection. At the same time, it becomes more and more unlikely that a selection will occur at all within a certain amount of time; this decreases the amount of information transmitted per time (information flow, or bitrate). In between, a certain value will correspond to an optimal compromise between selection errors, and selection duration. At this point, the flow of information is maximized.
The meaning of the actual number entered into the MinimumEvidence parameter is relative to the amount of within-class variance present in the classification score. An evidence of 0 means a 50:50 chance for correct classification. Increasing the evidence value by two standard deviations corresponds to an improvement by a factor of roughly 88:12, four standard deviations correspond to (88:12)^2=(98:2) ... etc, approaching perfect classification as evidence increases towards infinity.
In classifier training, classifier weights may be normalized such that within-class variance is 1 (this is done by BCI2000Analysis, and recent versions of the P300Classifier tool). In this case, you may use the following equations to convert between the MinimumEvidence parameter η, and the correct classification chance χ:
χ=5050(8812)η/2.
For large χ, this relationship may be approximated and expressed in terms of error probability p:
η≈−log10plog10e=−2.3log10pforp≤5%.
Thus, the evidence value roughly corresponds to twice the number of leading zeros in the desired error probability, if classifier weights are normalized. Some values are provided in the following table:
Selection Error Evidence
5% 3
1% 4.6
0.5% 5.3
0.1% 6.9
0.05% 7.6
0.01% 9.2
AccumulateEvidence
By default, only those classification scores are used which have been received from the signal processing module immediately prior to classification. When AccumulateEvidence is set, classification scores are accumulated until a selection is actually performed. Typically, accumulated classification scores will have higher evidence values, such that a selection threshold set with MinimumEvidence will be eventually crossed after scores have been accumulated for some time.
This allows for dynamically choosing the number of stimulus repetitions in a P300 paradigm, by setting the number of stimulus repetitions to 1, and setting the MinimumEvidence parameter to a value greater zero.
In addition, accumulated overall evidence will not increase if there is no consistent evidence in favor of a certain target. Thus, it is possible to operate a P300 BCI in a quasi-asynchronous mode by using AccumulateEvidence, and choosing a MinimumEvidence value that is large enough to make accidental selection unlikely. In this configuration, no selection will be made unless the BCI user is actually concentrating on a target for a number of stimulus presentations, resulting in consistently accumulating evidence for that target.
PhotoDiodePatch
Display a photo diode patch on the stimulus window. Recording from a photo diode located on that patch will allow triggering on actual stimulus delivery (see User_Reference:P3TemporalFilter#OnsetExpression).
PhotoDiodePatchHeight
Photo diode patch height in relative coordinates (between 0 and 1).
PhotoDiodePatchWidth
Photo diode patch width in relative coordinates (between 0 and 1).
PhotoDiodePatchLeft
Photo diode patch left position in relative coordinates (between 0 and 1).
PhotoDiodePatchTop
Photo diode patch top position in relative coordinates (between 0 and 1).
PhotoDiodePatchShape
Photo diode patch shape: 0 rectangle, 1 ellipse.
PhotoDiodePatchActiveColor
Photo diode patch color when active (RGB color in format 0xrrggbb).
PhotoDiodePatchInactiveColor
Photo diode patch color when inactive, (RGB color in format 0xrrggbb, use 0xff000000 for transparent).
PhotoDiodePatchExpression
Photo diode patch expression, determines active state by evaluating to nonnull. Defaults to StimulusBegin>0.
