User Reference:BCI2000Launcher
The BCI2000Launcher program provides a convenient user interface for organizing BCI2000 applications and parameter files. The Source, SignalProcessing, and Application modules are selected from a list, and multiple parameter files can be loaded.
Using BCI2000Launcher
Selecting Core Modules
On the top left, a tab control displays Source, Signal Processing, and Application modules available. From there, modules may be selected by double-clicking them.
Selected modules will be displayed in the Selection pane below the tab control.
Selecting Extensions
A single click on a module in the tab control will display extensions present in that module at the top right of the window. Each extension may have one or more "enablers", i.e. command line parameters that enable functionality from that extension when present. Enablers may be selected by checking group boxes displayed to their left.
When an enabler is active, it is displayed to the right of the currently selected module in the Selection pane.
Selecting Parameter Files
A very useful feature of the BCI2000Launcher is the ability to load multiple parameter fragments. One or more fragments can be added to the list to be loaded by pressing the "+" button, and selecting the *.prm files. Files can be removed from the list using the "-" button. If more than one prm file contains the same parameter, files lower on the list will have precedence over those higher on the list.
Double-clicking a parameter file will bring up a parameter window displaying the contents of the parameter file.
Entering Recording Parameters
The SubjectName, SubjectSession, and DataDirectory parameters may be entered directly in the BCI2000Launcher dialog. These values take precedence over the parameters' values in one of the specified parameter files.
Entering Scripting Commands
In the Scripting Commands text field, you may enter Operator Scripting commands. These will be executed once all modules have been connected, and after parameter files have been loaded and recording parameters applied.
Starting a BCI2000 Session
Select the desired module from each tab by double-clicking, and click the "Launch" button in the bottom left corner.
