User Reference:GDFFileWriter
The GDFFileWriter component writes out data in the GDF File Format.
In addition to the parameters provided by the EDFFileWriter, the GDFFileWriter provides an option to define mappings between state variables and GDF events.
These are storage parameters common to all Data File Formats.
DataDirectory
DataFile
The path to the data file relative to the directory, including the file name.
The DataFile parameter is a string that may contain references to other parameters in the form ${Parameter}. By default, it contains a session directory, named according to the ${SubjectSession} parameter, and a file name containing the ${SubjectRun} parameter along with the session number, and a date.
Date variables: The user can introduce date and/or time into the file name. One may enter ${DateTime:<format string>} to add date and/or time in an arbitrary format. <format string> must be a date-time format string as defined for the POSIX strftime() function. For example, ${DateTime:%F} will produce the date in the standard format YYYY-MM-DD. Be careful with time formats which will typically contain the : character, which is illegal in Windows file names. To produce both date and time, use ${DateTime:%F-%H-%M-%S}.
NOTE: When the file name contains both a run number, and a date/time string, auto-incrementing the run number will not work properly. Auto-incrementing the run number depends on all other components of the file name being constant, which is not the case for date and time.
SubjectName
A textual ID for the subject. This text may appear in session directories, and data file names.
SubjectSession
A textual ID for the current session. Sessions correspond to data directories. By default, the path of a session directory is constructed according to
${DataDirectory}/${SubjectName}${SubjectSession}
SubjectRun
A number indicating the current run. Runs correspond to data files. To avoid accidental loss of data, run numbers are auto-incremented to the largest unused value. Within a session directory, data file names are by default constructed according to
${SubjectName}S${SubjectSession}R${SubjectRun}.${FileFormat}
By default, a data file's extension depends on its File Format.
ID_System, ID_Amp, ID_Montage
FileSplittingCondition
While recording, recorded files may be split into multiple files with part2, part3, ... partN appended to the file name (before the extension). The first file will not be renamed to part1, though. When a condition is entered into the FileSplittingCondition parameter, it will be evaluated after each block of data has been written. Each time the condition is fulfilled, the old file will be closed, and a new one will be opened. Each partial file will be a valid file in the chosen FileWriter's format in its own right; only file names will carry information about how files should be combined to result in the full run file.
Conditions are simple strings representing either
  • a temporal duration, e.g. 00:00:30 for a duration of 30 seconds, or
  • a file size, e.g. 1.5MB for a size of 1.5 megabytes. Units of kB, MB, GB, TB and kiB, MiB, GiB, and TiB are supported. Prefixes without the i will refer to powers of 1000, whereas prefixes with an i refer to powers of 1024.
By default, the FileSplittingCondition parameter is empty, i.e. no file splitting occurs.
PrimaryOutputChannels
List of channels stored into the primary output file (see SecondaryOutputFiles below). Channel names may contain * and ? wildcards, and character ranges enclosed in []; wildcard patterns may be negated by prepending an exclamation mark. Ranges of channels may be specified using : or - to separate begin from end.
By default, this is set to "*", indicating that all channels should be recorded.
Examples:
1-8         // the first 8 channels
1-8 !4      // the first 8 channels except the 4th
EEG*        // wildcard pattern that matches all channels beginnning with "EEG"
MCQ01-MCQ23 // range of channels by name
A matrix where each row corresponds to a secondary output file. Columns are:
name
A string that identifies the output file. When constructing a file name, that string is appended to the run's base name. Example: When "name" is "EEG", and the primary output file's name is "Wilbur001Run02.dat", then the secondary file name will be "Wilbur001R02.EEG.dat".
prefix
A string that is prepended to the output file name, separated with a dot. This may be used alternatively, or in conjunction with "name". The combination of "prefix" and "name" must uniquely identify the output file.
channels
A channel list as described for PrimaryOutputChannels above.
decimation
An optional integer decimation factor used to downsample the secondary output file's data. Before downsampling, a 3rd order IIR filter is applied to avoid aliasing artifacts. Note that the decimation factor must also be a divisor of the sample block size.
SavePrmFile
Determines whether a BCI2000 parameter file is saved along with the GDF file. As of version 2.1, GDF is able to represent BCI2000 parameters, and parameter information is no longer lost if SavePrmFile is switched off. This parameter is optional, and will not appear in the parameter configuration dialog by default. To use it, specify --SavePrmFile=1 on the command line when starting up the source module.
GDFFileWriter Specific Parameters
SubjectYearOfBirth
Year the subject was born, in YYYY format.
SubjectSex
An enumerated value specifying the subject's sex:
  • 0: not specified,
  • 1: male,
  • 2: female.
TransducerType
A string describing the transducer (sensor) type, e.g. EEG: Ag/AgCl.
SignalUnit
A string specifying the physical unit of the calibrated signal. Differently from the notation used throughout the rest of BCI2000, this is usually "uV" rather than "muV".
EquipmentID
A string identifying the equipment provider. Since GDF version 2.0, the equipment ID field has been 8-byte numeric rather than string-valued. Consequently, the EquipmentID parameter is treated as an integer value, and written into the numeric field. If the parameter string evaluates to 0 -- e.g., because it begins with a letter rather than a digit -- its first 8 bytes are copied into the numeric equipment ID field in a byte-wise manner. Remaining bytes are padded with zero bytes if the parameter's string representation contains fewer than 8 characters.
EventCodes
BCI2000 does not prescribe the meaning of its state variables. GDF, on the other hand, associates a fixed set of events with certain numeric codes. Thus, a general mapping of BCI2000 states onto GDF events is not possible. Instead, GDF events are created via a user-defined set of mapping rules in the EventCode parameter, which also has a set of rules predefined for the most important cases.
The EventCodes parameter is a two-column matrix, with each row associating a boolean expression with a hexadecimal event code as defined in the GDF File Format. The expression is evaluated for each data block. Whenever its value switches from "false" to "true", the GDF event code from the second column is entered into the GDF event table; whenever its value switches back from "true" to "false", the same event code is entered into the table but with the most significant bit set to 1 (bitmask 0x8000).
The default value of the EventCodes parameter defines the most common mappings between BCI2000 states and GDF event codes:
Condition Code GDF Event
TargetCode!=0 0x0300 trial begin
TargetCode==1 0x030c cue up
TargetCode==2 0x0306 cue down
(ResultCode!=0)&&(TargetCode==ResultCode) 0x0381 hit
(ResultCode!=0)&&(TargetCode!=ResultCode) 0x0382 miss
Feedback!=0 0x030d feedback onset
In addition to GDF events, BCI2000 state variables will be mapped to additional signal channels the same way as for EDF.
User Reference:DataIOFilter, User Reference:Data File Formats
