User Reference:LPFilter
The LPFilter is a simple single-pole temporal low pass filter with a time constant T (given in units of a sample's duration), a sequence Sin,t as input and a sequence Sout,t as output (where t is a sample index proportional to time), and obeying
Sout,0=(1e1/T)Sin,0
Sout,t=e1/TSout,t1+(1e1/T)Sin,t
Typically, the LPFilter would be used to remove high-frequency noise from the Classifier's output.
LPTimeConstant
The filter's time constant in units of sample blocks, or in seconds if followed with an "s".
Consistent with its mathematical limit, a value of
LPTimeConstant= 0
disables the LPFilter.
Programming Reference:IIRFilterBase Class
