User Reference:Python FileLoader
The BCI2kReader package allows to read BCI2000 .dat files in Python. The reader is written completely in python and works with python 2 and python 3.
Installing the package
The package can either be installed with the python package manager (pip) or you can download the latest version from GitHub.
To install the package via pip:
pip install BCI2kReader
To get the latest (development) version from GitHub
git clone https://github.com/markusadamek/BCI2kReader
To Install the development version move to the cloned directory and run:
pip install .
Usage
To use the reader you have to create a BCI2kReader object, which inherits from io.IOBase. The reader has two basic modes, caching and non-caching. In caching mode, the BCI2kReader object will retain the data in memory as soon as a full readout of the file has taken place. If you need to save memory, the BCI2kReader object also supports that all read operations are done directly from the file.
Reading a File
The simplest way to open a file is with pythons with command (see https://docs.python.org/3/tutorial/inputoutput.html#methods-of-file-objects for more information about file IO and the with statement).
from BCI2kReader import BCI2kReader as b2k
with b2k.BCI2kReader('yourbci2000testfile.dat') as file:
if you want to open the file without caching enabled:
with b2k.BCI2kReader('yourbci2000testfile.dat', False) as file:
It is also possible to clear the cache to free memory:
file.purge()
Getting Data from the object
The easiest way to get the data is to use the properties for signals and states. The signals are provided as a numpy ndarray with the dimensions (channels, samples). The states are provided as a StateDictionary which inherits from dict with the state name as key.
eeg_data = file.signals states = file.states
