User Reference:Module Command Line Options
Using command line options allows you to
  • distribute BCI2000 modules over a network,
  • change the data format for brain signal recordings,
  • switch on debugging messages,
  • automate BCI2000 operation.
You cannot use command line options when starting BCI2000 from BCI2000Launcher. Rather, copy one of the batch files from the BCI2000/batch directory, and modify it to fit your needs, then start BCI2000 by double-clicking it (this will work on all supported platforms, not only Windows).
Core Modules
Core modules (i.e., Data Acquisition, Signal Processing, and Application Module), share the same command line syntax:
<ModuleName> <operator IP>:<operator port> --<option1>=<value1> --<option2>=<value2> ...
All arguments are optional.
Specifying the Operator Module's Network Address
At startup, each core module connects to the operator module. If no IP address is specified on the command line, the connection is opened to the local machine using 127.0.0.1 as an IP address. When no port is given, each module uses its default port as defined here. Normally, there is no need to change port numbers.
Specifying Options
Any number of options may be given, starting with a double minus sign. As indicated above, option names and values are combined with a single minus sign, to form a continuous character string. Each option is translated into a BCI2000 parameter using its name as a parameter name, and its value as a parameter value. When a parameter with the given name already exists, its value will be changed from the default to match the value given on the command line. When no parameter with that name exists, it is added to the System parameter section. Parameter values must not contain white spaces on the command line; however, white space may be encoded in HTTP fashion as described here, e.g., using '%20' as a replacement for a single space character.
Special Options
  • Specifying --version will display version information, and then quit.
  • Specifying --Extensions will display a list of extensions present in the module, along with their "enabler" parameters.
  • The FileFormat option will switch between File Formats used for data recording. The output file format is determined at module startup, and cannot be changed by modifying the FileFormat parameter from the operator module's parameter dialog.
  • The DebugLevel option will make a module send Debug Messages that appear in the operator module's log window. By default, the debug level will be set to 1; providing a larger number, as in DebugLevel=5, will increase verbosity of debug output.
  • The DebugLog option will maintain a log file in the current session directory, bearing the session name, and a .dbg extension. A DebugLevel>0 will imply DebugLog=1, unless DebugLog is explicitly set to 0.
  • The LogKeyboard, LogMouse, and LogJoystick options will enable recording of key presses, mouse and joystick position.
  • The SavePrmFile option will save a parameter file for each run.
  • Normally, BCI2000 automatically chooses suitable IP addresses for communication between SignalSource, SignalProcessing, and Application module. Sometimes however, you want a specific address to be used, e.g. if you distribute BCI2000 over multiple machines, and need a certain address to be used. This is possible using the ListeningAddress option. Note that this options must be specified on the command line of the respective module, e.g. the following lines will specify the localhost address for both the connection to the Operator module (first option), and the connection between core modules:
start executable SignalSource 127.0.0.1 --ListeningAddress=127.0.0.1
start executable SignalProcessing 127.0.0.1 --ListeningAddress=127.0.0.1
start executable Application 127.0.0.1 --ListeningAddress=127.0.0.1
  • The --local option provides an alternative way to set a module's listening IP to 127.0.0.1.
  • By default, only one module of each kind may be running at a time. To allow for multiple instances of a module, specify the --AllowMultipleInstances option. This will also clean up any instance information that may have been left over from a crashing module.
Operator Module
The Operator Module allows to specify scripts from the command line. Most command line options correspond to script entries in the operator's preferences dialog. The following options exist:
--OnConnect
--OnExit
--OnSetConfig
--OnSuspend
--OnResume
--OnStart
--OnStartRun
--OnStopRun
--Title
--Hide
--StartupIdle
--Startup
--Telnet
--WebSocket
After the option, white space is expected, followed with a double-quote enclosed string. Examples:
--OnConnect "C:\scripts\onconnect.bciscript"
--OnConnect "-LOAD PARAMETERFILE ..\parms\myparms.prm"
--Telnet
--Telnet 192.168.1.5:3999
--Title
The --Title option takes a string that is displayed in the Operator Module's title bar.
--Hide
The --Hide option has no arguments. It hides the Operator module's main window (but not visualization windows). Typically, this option is used in conjunction with fully automated execution via OnConnect/OnSetConfig/OnSuspend scripts, or together with the --Telnet or --WebSocket option.
--Telnet
The --Telnet option expects an IP:Port combination on which to listen for incoming connections, defaulting to "localhost:3999". Logging into the Operator Module's telnet server allows you to execute script commands interactively, or to remotely control BCI2000 from an external application using script commands. When you intend to connect to the Operator Module from a different machine, you will need to specify either an asterisk (*) in place of the IP address: "*:3999" to indicate that it should listen on all available addresses, or the listening machine's external IP address, e.g. "192.168.1.5:3999".
Multiple --Telnet options may be given to start multiple telnet servers on different addresses.
NOTE: You should not use this option on global internet addresses, as there is no authentication performed. Be especially careful with the "*" address, as it opens all addresses, possibly open internet addresses as well.
--WebSocket
Similar to the --Telnet option, the --WebSocket option expects an IP:Port combination for incoming WebSocket connections, defaulting to "localhost:3998" (the WebSocket URL would be "ws://localhost:3998/"). The WebSocket port exposes the same functionality as the Telnet port, but wrapped into the WebSocket protocol, allowing browser clients to communicate with BCI2000 in JavaScript (for security reasons, browser-based JavaScript cannot use raw TCP or UDP sockets).
--StartupIdle
When the --StartupIdle option is specified, the Operator module does not wait for incoming connections from BCI2000 core modules. This allows for basic configuration to be performed via a telnet or WebSocket connection. To prepare for core module startup, execute
Startup System
from the telnet prompt.
--Startup
Here, you may specify system startup arguments (address, module names, and ports) as specified for the STARTUP SYSTEM scripting command. Typically, you will need to enclose the arguments in double quotes.
By default, only one instance of the Operator module may be running on a system at a time. To allow for multiple Operator instances, specify the --AllowMultipleInstances option.
--InstancePrefix
A prefix to use in Operator module window title bars. This is useful when running multiple instances of the Operator module at the same time. Also, the instance prefix will be used to separate persistent settings in the Operator .ini file (such as window position and size) by storing them to a different .ini file named <prefix> Operator.ini.
For further details and examples, see User Reference:Operator Module Scripting.
Technical Reference:Core Modules, User Reference:Operator Module Scripting, User Reference:Data File Formats, Programming Reference:Debug Output, User Reference:Logging Input
